Re: Help Engine Seizing issue!
Posted by mkirsch on November 09, 2011 at 13:20:00 from (64.80.110.75):
In Reply to: Help Engine Seizing issue! posted by Dan Cooley on November 09, 2011 at 12:03:37:
Did you check the ring gap before installing them on the pistons?
I find it hard to believe new rings in an old sleeve would be too tight, but I suppose it's possible especially if you put "oversize" rings in it in a misguided attempt to compensate for sleeve wear.
It's not a timing problem, for sure. Timing has no bearing on the engine when the ignition is switched off.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
