Help Engine Seizing issue!
Posted by Dan Cooley on November 09, 2011 at 12:03:37 from (72.227.91.45):
I have a a 1946 Farmall Super A, I just put new rings on the pistons and adjusted the valves, i got it going but am having a issues with it seizing up after running it, it only seizes when i shut it off and as soon as stops turning. it has plenty of oil and plenty of coolant so i dont think it is a lubrication issue. could it possibly be a timing problem where the connecting rod hasnt made it past the peak of the turn on the crank shaft? when it does seize it comes free when i pull it with another tractor or truck and pop the clutch when in gear
you help would be greatly appriciated! i want to get this problem fixed cuz every time i use the tractor i fear shutting it off when in the field working cuz i would have to go get a truck or tractor to pull it and unfreeze it!
Thanks Dan
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
