Re: Help Engine Seizing issue!
Posted by Janicholson on November 09, 2011 at 13:26:43 from (199.17.6.77):
In Reply to: Help Engine Seizing issue! posted by Dan Cooley on November 09, 2011 at 12:03:37:
The starter may be locking on the Flywheel, and not siezing at all. Try loosening the starter when it (Siezes) to see if it is jammed. It will click while loosening the bolts. Or you could push it in high gear by hand a little ways to see if the engine is stuck before you try starting it. A new and improved starter drive is available to fix that problem. If it is stuck for real when shut off, I would agree the ring endgap, or carbon under the rings in the grooves will cause the issue. Does the engine get tight and run with ever increasing difficulty and reduced power just before shutting it off? if so that is a sign of siezure and not of the starter issue i mention. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
