Re: Re: Re: Re: Re: Help with Farmall C carb
Posted by Rich Cota on August 28, 2000 at 13:56:07 from (198.56.12.237):
In Reply to: Re: Re: Re: Re: Help with Farmall C carb posted by FC on August 28, 2000 at 13:41:04:
Yes, it can affect idle if valves leak bad enough. Low vacuum affects the engine more at speeds above idle.As you increase the rpm the vacuum needs to increase to suck in more fuel.
Post A Followup
: Re: Re: Re: Re: Re: Re: Help with Farmall C carb
