Cub is running
Posted by Chief 83 on November 09, 2011 at 20:04:11 from (24.21.76.219):
Finally have the Cub running. Idles great and runs smooth. The only issue now is when you give it fairly rapid throttle is chokes a bit and may or may not pick right up. If you pull the choke about 30% is is less of a problem but is still not right. I've checked the timing and also tried it a couple of degrees either way. No improvement.Since the problem is decreased by pulling the choke I assume carb related. The carb has a new rebuild. Any ideas??
