Re: Cub is running
Posted by JRSutton on November 10, 2011 at 05:02:20 from (75.130.109.233):
In Reply to: Cub is running posted by Chief 83 on November 09, 2011 at 20:04:11:
Old basic carbs will always lag quite a bit on a fast move of the throttle. They don't have an accelerator pump. So it'll never be perfect.
But if it feels like it's a problem, and as you say choking it a bit helps, then it's most likely clogged somewhere in the carb.
Rebuilding a carb doesn't clean it. And blasting it with carb cleaner when its apart is almost never enough to really clean it.
You really gotta get into the little passageways with a wire - or boil it. Or better yet, use an ultrasonic cleaner (see link).
For 80 bucks, you'll be the most popular guy on the block when everybody wants to clean their carburetors.
I found a video too - can't seem to link more than once here - I'll repost with that link
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
