Re: decal placement on C
Posted by soundguy on November 10, 2011 at 12:31:05 from (184.4.159.38):
In Reply to: Re: decal placement on C posted by Scotty HOMEy on November 10, 2011 at 10:10:46:
ok, i also have a oil filter decal.. ... I assume on the oil canister
next is an air cleaner, again.. assume onthe upper body?
gear shift pattern decal
also the lamp switch decal i guess.. I have a possibility of 2.. lh d b or O D B
i'm guessing off /dim / bright
not sure what the LH one is.
I have a rear work lamp and r & l front lamps off the steering pedistal.
and I checked my switch, dim / bright works, and all 3 lamps function
thanks
