Re: Cracked Block
Posted by teddy52food on November 10, 2011 at 17:20:03 from (209.237.115.153):
In Reply to: Re: Cracked Block posted by soundguy on November 10, 2011 at 14:25:09:
My Super C had a crack there too. I welded it with 99 nickel rod at least 35 years ago & it is still dry today. I don"t know why they crack there. Must be a weak spot in the casting.
