Re: Cracked Block
Posted by soundguy on November 10, 2011 at 14:25:09 from (173.105.12.58):
In Reply to: Re: Cracked Block posted by Livin the Dream on November 10, 2011 at 12:20:52:
in that area, you could always strip it down, lay it over clean up real well and braze or silver solder it, if it is only an external leak.
aftrer cleaning and wire wheel, and a slight grooving, tons of flux and silver solder will be easiest.. followed by brazing next..
I've fixed a ford block with a similar crack.. I know it's been dry for years now..
soundguy
