Re: re-post with more info-fresh 460 gasser over haul- bu...
Posted by NolanJae on November 12, 2011 at 06:02:05 from (156.98.127.101):
In Reply to: Re: re-post with more info-fresh 460 gasser over haul- bu... posted by janicholson on November 11, 2011 at 18:34:30:
a non centered cam shaft gear really sounds scary and may cause me to sit and cry for a while. After all the work rebuilding this. I was under the understanding that the cam shaft gear was machined into the cam and could not be moved. I would hope that uneven teeth would be an automatic check when its reground and re-heat treated. Or would it not be. Could it be off center because of new cam bushings? I would also think that the new bushings alone would correct the old condition unless the pump is worn out. How would that get moved or be moved. I never removed the cam prior to the overhaul and all the cam work was done by the shop except the reinstall which I did. With that gear being re ground and heat treated I would hope it would wear out the oil pump before the cam teeth.
