Re: re-post with more info-fresh 460 gasser over haul- bu...
Posted by janicholson on November 12, 2011 at 08:07:04 from (96.24.99.126):
In Reply to: Re: re-post with more info-fresh 460 gasser over haul- bu... posted by NolanJae on November 12, 2011 at 06:02:05:
Depending on a variety of factors not known by anyone but the cam grinder, here is my take.
The distributorwobbles when a bit loose.
The reason for this is mechanical motion coming from the coupling between the oil pump drive gear and the distributor shaft.
The wobble is generated from either a bent end on the distributor, a bent or abnormally worn drive on the pump, a worn pump gear with teeth that engage the cam gear eccentrically, or a cam gear that is not concentric with the cam Centerline, and causing the oil pump drive gear to be pushed out and in.
I cannot tell you which it is, or if there is wear on bushings.
Measurement will do that, a set of telescopic bore gauges, micrometers and dial indicators are needed.
Cam bearings are not going to cause the issue.
Cam gears are hobbed into the cam metal, not added on. If a heat treatment process goes wrong, it can warp metal and cause issues. If the same cam that was in it is reground, and it was bad in the concentricity of the gear, it will not be fixed or checked buy the grinder. unless suspected, it was not.
If the wobble is not found by eye, it will be necessary to measure. Jim
