706 rear end fluid
Posted by Ardie on November 12, 2011 at 06:52:29 from (174.74.66.133):
I changed filter and hy tran fluid on my 1963 Farmall 706 diesel. I can't find info on how much hy tran fluid goes into the transmission. There is a plug on each side of housing. I am asumming that is where you fill it, but don't know how much fluid. What I need to know is how much fluid and do I fill it till the fluid runs out the plugs.
Thanks for your time.
