Posted by Owen Aaland on November 12, 2011 at 12:07:32 from (216.47.32.147):
In Reply to: 706 rear end fluid posted by Ardie on November 12, 2011 at 06:52:29:
The plugs on the sides of the final drive housings are for the oil in the final drive units. On the original 708/806 these housings did not have a common reservoir with the transmission and rear end. The were drained and filled separately. It is a common practice to droll holes in the rear frame to allow the oil from transmission to also fill the final drive housings but when that is done the head of the check/fill plug is to be cut off to indicate that it is no longer necessary to fill it separately.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
