Re: 574
Posted by Jimb2 on November 12, 2011 at 10:09:26 from (174.115.9.174):
In Reply to: 574 posted by Kevin Roberts on November 12, 2011 at 07:54:41:
Hi Kevin, never worked on a gasser, only the Diesel D-239 version. I believe the gas engine was a C-200 and it should be stamped on right side of engine by the oil filler/dipstick. Because these engines were used in many different applications, there was a separate parts book for each engine, so go to caseih.com search for parts and enter C-200 instead of 574.
JimB
  • Re: 574 Kevin Roberts 15:57:54 11/12/11 (0)
