574
Posted by Kevin Roberts on November 12, 2011 at 07:54:41 from (67.142.175.21):
Just took delivery of a 574 gasser with a few issues. There is a bolt in the block right above the solenoid that is dripping oil. Not sure if something was supposed to be in the block at that location and this is a plug or if the bolt is factory there. Either way, it's dripping and just wondering if there is something missing or just needs a gasket or o-ring. Tried looking at IH Parts, but there was no category for engine in the parts look-up.
Another issue is that when I put the position control lever all the way to the NOTCH, or lower fast position, three point drops really slow or not at all. When I pull it just above the notch, it lowers fine.m I have the draft control in lock out position.
These are the beginning issues. Bought her knowing she needed a little work.
  • Re: 574 DeltaRed 18:44:02 11/12/11 (2)
    • Re: 574 Kevin Roberts 09:08:52 11/13/11 (1)
      • Re: 574 Jimb2 10:37:58 11/13/11 (0)
  • Re: 574 mike van 14:19:07 11/12/11 (1)
    • Re: 574 Kevin Roberts 16:03:00 11/12/11 (0)
  • Re: 574 Jimb2 10:09:26 11/12/11 (1)
    • Re: 574 Kevin Roberts 15:57:54 11/12/11 (0)
