Re: 574
Posted by DeltaRed on November 12, 2011 at 18:44:02 from (71.215.111.150):
In Reply to: 574 posted by Kevin Roberts on November 12, 2011 at 07:54:41:
Look closely at the bolt.Determine if the bolt uses an o-ring,a copper washer,or just needs some teflon tape.Soumds to mee that it is in an oil galley.
  • Re: 574 Kevin Roberts 09:08:52 11/13/11 (1)
    • Re: 574 Jimb2 10:37:58 11/13/11 (0)
