Re: wow.. expensive tires!
Posted by mkirsch on November 14, 2011 at 05:55:17 from (64.80.110.74):
In Reply to: wow.. expensive tires! posted by 36F30 on November 12, 2011 at 17:21:22:
Well, let's see....
1. You might not like the way they look. Car tires just make a tractor look "junky." If the tractor is all painted up nice, it looks like a pig wearing lipstick with old bald car tires on the front.
2. You might not like the way they take a load. Car tires are not designed to handle heavy loads like tractor tires. Tractor tires have a stiffer sidewall, and can handle 50-60 PSI. Car tires max out at 44PSI. Even if you pump the car tire up to 50-60, it still squats under a load.
3. You might not like the way they handle. The ribs on a tractor tire serve a purpose: When you turn the steering wheel the tractor turns. Smooth car tires will just slide sideways in field conditions.
