Posted by pete 23 on November 14, 2011 at 10:56:59 from (74.32.238.142):
In Reply to: 706 HITCH PUMP QUESTION posted by KY PLow Boy on November 13, 2011 at 18:28:51:
That pump is also used in piggy back installations and then the plate comes off the back and another pump goes on there and that would be the discharge for that pump. No o-ring needed on yours. If you still have pump off, put aux valve on demand, apply air pressure to port in rear frame and listen for leaks, should be none or just a tad if any. With aux in neutral it should blow through. May have a blown sealing ring on rear cover.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
