Nolan, Well done diagnosis. This has been an interesting (for the Forum) and frustrating for you issue. I also have no clue what size it should be in inches. I will indicate that there is reasonable and historic evidence that the replacement will be only moderately worn, and not a problem. I would measure the new components and if the difference between the two sizes is between .002 and .006 I would accept that as OK. When new it might be in the area of .001 to .002. (a guess based on sizes in other distributor drive gear to housing measurements, and reasonable expectations. Someone cobbled the gear back together with either the wrong key, or a chip of incompressible material under it. Poor workmanship. May the pulley replacement go well, and the distributor not wobble. In my experience, I would put it together with the good pump and new hold down bracket adjust the static timing, and tighten it up. Do not loosen the distributor ti "see" if it wobbles. Cam angle variation is the enemy. Use a timing light on the pulley with the pickup placed on several of the plug wires in succession. Look not for the timing mark, but for the image in the flash to be solid and not jumping around forward and back. The solidity is an indication of pretty good timing stability. A distributor analysis machine (Sun or other old machine that uses the distributor out of the vehicle) will be the best for accurate analysis of cam angle variation, and dwell. Call around to find one being used. An oscilloscope will also do it if the operator is an artist with it. Best of luck, the answer is in hand. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
