574 runs very rich
Posted by sean martin on November 15, 2011 at 13:39:22 from (166.248.38.124):
hello im new to this so here we go i have an international 574 gas tractor,had tractor a part to put a clutch in it so everthing was apart so in between waiting for parts i cleaned the carb wasnt really bad but anyhow i got everything back together and tractor runs very rich will chase you out of the garage in less than 5mins,raw fuel on inlet side of carb did put a new fuel shut off solenod on it,also did a tune up cap rotor wires and even a new fuel pump old was leaking what should i look for dont wanna get stuck snows on its way and i need firewood and a clean driveway
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
