Posted by John M on November 15, 2011 at 15:54:56 from (67.231.174.220):
In Reply to: 574 runs very rich posted by sean martin on November 15, 2011 at 13:39:22:
Assuming you have it set right, you may have damaged the float. Id pull it back apart and make sure all of that is moving good. A little trick, while its running, shut the fuel off and let it run out. If it gets better, its too rich.If not, its something else.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
