Posted by gene bender on November 17, 2011 at 06:51:39 from (67.55.226.244):
In Reply to: Axle removal posted by freefour on November 17, 2011 at 05:45:27:
I use a strap around the final then remove the bolts holding it to the tranny the whol assy will come out easy. Then after removing the brake drum the shaft will come out thru the final after removing the small plate that has the four bolts holding the cove. This is for the left side. Right side is a little different with seat and floor pan all fastend to the housing. You will need to get the floor pan loose and out of the way to remove the housing. After getting the right side removed the brake drum will need to be removed so the diff shaft can come out thru the same plat the left side has. Quite a job but ive done it several times so its easy for me but the cherry picker is a must.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
