Re: Suicidal Super C
Posted by Chris on August 29, 2000 at 19:26:41 from (63.24.79.233):
In Reply to: Suicidal Super C posted by Z on a Super C on August 29, 2000 at 19:03:55:
If your coil is getting hot Then the power suppley is not being interupted.
A constent voltege will cause it to get hot. It is possable the the dieletric material holding the points is bad ( conductive ) .
Try this disconect the wire coming from the points to the coil connect it to an ohm metter hold the other lead to ground whith the points closed you should have conntenuity when you brake the points you should lose all conntenuity . if you keep conntenuity the points have a leake to ground .
Post A Followup
: Re: Re: Suicidal Super C
