Posted by mkirsch on November 18, 2011 at 12:11:36 from (64.80.110.74):
In Reply to: 154 won't fire posted by pheel on November 18, 2011 at 07:22:15:
DO NOT try 24 Volts! You will ruin the starter/generator and regulator.
Just because a battery is new doesn't mean it's fully charged. Put it on a battery charger overnight and try again.
Taking the belt off and running the starter tells you nothing. Even a bad starter will run full speed without a load on it.
If your battery is fully charged, AND the cables are good/clean/tight, AND the switch isn't burned, AND it still doesn't turn over very fast, you have a bad starter motor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
