154 won't fire
Posted by pheel on November 18, 2011 at 07:22:15 from (166.147.115.200):
i followed the instructions i got and the 154 is firing but it is not turning over fast enough to start it is very slow, the battery is new with 630 amps, can i jump it also will tht make it crank fster or how do you connect batteries to get 24volt it has not run in a long time if you remove th belt the startr spins at full speed
