Posted by JT on November 18, 2011 at 17:37:42 from (68.53.181.110):
In Reply to: 154 won't fire posted by pheel on November 18, 2011 at 07:22:15:
By meaning it won"t fire, do you mean it will not start or it has no fire? They are two totally differant things. You do need a 22nf battery to turn it over, do you do have the correct amperage battery. If the engine is just turning slow, I would check the brushes on the str/gen, they can be worn, springs weak, or the commutator is dirty, unless you have some experience in that field, take it to a shop that does that. If it has no fire, then you need to to check for voltage to the coil, check your points for fire would be the first two things to look for. If you will post what your exact problem is, maybe someone can help you a little better Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
