Re: Super C - C123 compression when cold
Posted by Tom Fleming on November 20, 2011 at 14:27:57 from (206.193.250.146):
In Reply to: Super C - C123 compression when cold posted by hatrick on November 20, 2011 at 13:19:26:
Run it awhile. change the oil. Silicone anywhere near oil passages is a BIG NO NO!. Pieces or spluge can break off and plug oil galleries and or the oil pump.
If you cleaned it up, and put a new head gasket on, run it awhile, change the oil and then take your compression. Quite possible it could stand a valve job, or minimally lap the valves.
Let us know how it goes.
