Posted by hatrick on November 20, 2011 at 13:19:26 from (199.48.194.238):
I have a Super C that I originally had 30 lbs of compression across the board. I discovered bathroom caulk on the head gasket and a mess of stuff in the valve chambers causing them not to seat. I Cleaned all of that up and put on a new head gasket. I adjusted the valves to .017 cold and now I have 60lbs across the board. Oil in the cylinders does not increase the compression. I suspect the engine may now run but the compression seems low. Since I do not know the history of this engine and sleeves look very good and maybe new is there anything else you can think of or is 60lbs OK cold. It is below 30 degrees today also.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
