If it will start, run it for several hours or for a total of several and get it warmed up well from load if possible. Then check compression. THe throttle must be wide open, the plugs out, and a fully charged battery to spin it fast enough to test accurately. It is also necessary to be sure your gauge is accurate, checking it with a known air supply or against a different gauge is important (unless you have a history with it and are comfortable with the readings) Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
