Re: MD split/engine swap
Posted by Janicholson on November 20, 2011 at 18:44:45 from (96.24.99.126):
In Reply to: MD split/engine swap posted by hatrick on November 20, 2011 at 18:35:44:
None of the above:
The rails must be removed, the rear supported by blocking the engine plate is between the FW and engine. The FW must be unbolted from the crankshaft after removing the clutch. The "new" engine will need to have a plate made for it, (assumes a different type of engine will be used) and mounts engineered for the front of the engine and throwout bearing ect. Best of luck.
Jim
