153 in a super C
Posted by Danny Hogge on November 21, 2011 at 00:28:18 from (70.61.202.74):
I'm in the process of istalling a 153 in a Super C.
I took out the crank to bore it out to install a pilot bearing.
Anyone out there that can tell me which bearing to use.
Also to someone that has done this swap can you tell me do I install the water pump from the 123 and the fan mount or use the 153 water pump and fan.
Please advise and thank you.
I also decided to install new rings and bearings while I have crank out anyway.
What is the torque requirements for the rods and main bearing bolts.
Tx.,
AGAIN.
Dan Sr.
