Re: Farmall F 20 oil pressure
Posted by robgIN on November 21, 2011 at 09:46:35 from (70.224.32.112):
In Reply to: Farmall F 20 oil pressure posted by Elden Russell on November 21, 2011 at 06:31:11:
you have to oil valves manually, should be felt wicks in trough under valve cover. If the troughs for the rod are full the pump is probably working and has a bad or wrong guage , do as Cowman suggests remove guage and crank over a few times should sqirt outsome oil.
