Re: Farmall F 20 oil pressure
Posted by Pete in Holland MI on November 21, 2011 at 10:54:46 from (198.36.95.11):
In Reply to: Farmall F 20 oil pressure posted by Elden Russell on November 21, 2011 at 06:31:11:
F-20's only run at 3-5psi normally. The pump only is used to pump oil up so it can be dribbled or splashed around, and move thru the filter. Nothing is pressurized on these ole girls.
Yes, the valves are oiled manually. Couple squirts once a day. Seems to have worked well, as the three I have owned had very little play in the rockers.
