Re: 10-20 head stud
Posted by JRSutton on November 22, 2011 at 05:03:16 from (75.130.109.233):
In Reply to: 10-20 head stud posted by dave2 on November 22, 2011 at 03:54:37:
Yeah - I'd find a good engine shop in your area and see what sort of options they can offer.
If you go oversize with a different stud - be sure whoever's doing the work understands engines. A stud is designed to have a certain amount of stretch when you torque it (or limited stretch depending on how you look at it).
You don't want somebody to just chuck up whatever they've got laying around to turn you a new stud.
To your advantage, these aren't race car engines, and the tolerances are a lot looser, but still. You don't want a head stud that stretches like a rubber band. You could end up warping your head.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
