Re: 10-20 head stud
Posted by oldiron29 on November 22, 2011 at 05:09:35 from (74.88.11.200):
In Reply to: Re: 10-20 head stud posted by Tom Fleming on November 22, 2011 at 04:09:32:
Tom, the head has been off 3 times allready!
when your torquing to 90-95# I don"t think the heilcoil will hold. I have thought about the custom studs and retapping block. I need a test for torque before I set the head. It is no fun to put the head back on with new gasket and than have a stud fail. This will be my late winter project. So I need to get my game plan started now. Mabe someone has run inti this kind of thing before. oldiron29
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
