Posted by Old-F20 on November 22, 2011 at 06:50:50 from (71.7.102.46):
In Reply to: 10-20 head stud posted by oldiron29 on November 22, 2011 at 03:54:37:
heres what i do. with over a dozen pre 39 engines built, it works.
HELICOIL!
ive had to deal with broken studs all the time since ALL the head studs are open to the water jacket. Ive had one block that alomst half the studs broke off and after trying to wled nuts to them and have them snap off again, i just set the block in the bridgeort and drilled out whats left of the stud. over bore it, re-tap it and stick a helicoil in it.
if you think it wont hold, ill let you come over and put a tourque wrench on an F-30 i built with 8000 foot pistons and .030 shaved off the head and tourqued to 125 ft pounds
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
