Super H Brakes
Posted by burnsg2003 on November 22, 2011 at 19:53:24 from (205.188.116.73):
My brakes on my super H are worn out. I have found where I can buy the replacement disc but on the brake assembly itself the brake expander arms are worn out or at least I think that is the proper name. Where can these be purchased along with the pins that connect them to the assembly.
How much should I expect to pay. Any other hints on redoing the brakes.Thanks
