Re: Farmall 560 hydraulic pump
Posted by pete 23 on November 29, 2011 at 10:27:58 from (74.32.238.142):
In Reply to: Re: Farmall 560 hydraulic pump posted by TWhit on November 29, 2011 at 03:20:25:
The regulator block sits right along side of the aux valves, right in vicinity where the large hose comes from pump, by clutch pedal. No draining necessary, just take the small cover off block. If shield is in place you will have to it first.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
