Re: Farmall 560 hydraulic pump
Posted by TWhit on November 29, 2011 at 03:20:25 from (97.119.41.101):
In Reply to: Re: Farmall 560 hydraulic pump posted by pete 23 on November 28, 2011 at 16:41:52:
The roll pins look good, Do I need to drain the hydraulic fluid and pull the pump out to get to the regulator valve assembly block?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
