Installing a tank type block heater on an M
Posted by Dr. Bert on November 29, 2011 at 11:45:57 from (72.36.56.185):
I want to install a tank type heater on my '49 M. Found a plug on the left side of the block just ahead of the carburetor and a plug on the left side of the water outlet casting. If I use the last mentioned, will the warmed water bypass the thermostat? Is there a bypass built into this casting to allow some water flow when the thermostat is closed? It is suggested in the archives to plug into the port in the head where the water temperature bulb is installed. Which would be best? Thanks.
