On my 53 SM ,the local dealer installed a tank heater sometime in the 70s, and it still works good even today ! It is mounted next to and just ahead of the carb, using the opening you mentioned for a short hose to the heater,then a long hose goes forward and wraps around the front of the engine above the water pump and along the block on the dist. side to where the temp gauge taps in. There are pipe fitting adapters there to plumb the hose nipple and tee for the original temp gauge sensor to still be used. It looks and works good this way. Most of the hose is hidden under the hood, but of course the heater itself is in plain view.It mounts with the bolts from the governor housing. Hope that helps! ~ Mike
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
