ih 826 nosteering,brakes , 3point or pto
Posted by Jeff Gibson on November 29, 2011 at 18:29:22 from (166.249.101.64):
Was using the 826 to grind feed Friday, Saturday I went out to bush hog with it and the steering wouldn't work. I tried the PTO and the 3point it doesn't work either. I am getting a loud screeching squalling noise from the tractor also. Any ideas? Started doing some online research and everything points to a stripped clutch disc problem. I haven't pulled any inspection covers yet. The fluid level is fine and the temp has been in the 50's so its flowing fine. Any other ideas? Dont look forward to having to split this tractor.
Thanks
Jeff
