Re: ih 826 nosteering,brakes , 3point or pto
Posted by DeltaRed on November 29, 2011 at 18:34:53 from (71.215.111.150):
In Reply to: ih 826 nosteering,brakes , 3point or pto posted by Jeff Gibson on November 29, 2011 at 18:29:22:
Yep,the pto drive and pressure plate splines are stripped-common problem.Will need to be split.While you are there,go ahead and do a complete 'clutch job'.
