Re: 12 volt conversion issue
Posted by old on December 02, 2011 at 08:00:50 from (209.86.226.56):
In Reply to: Re: 12 volt conversion issue posted by Scott Limbourne on December 01, 2011 at 19:49:30:
If the meter you used read 12.3 volts at the battery then 16 or so with it running then your meter is mist likely reading close enough for what your doing. You did not unhook a battery cable when you did the voltage test did you???? Reason I ask that is that is a good way to fry an alternator and also it would make an alternator put out max in doing so but I do not think you did unhook it but asked any how
