Re: M still not running
Posted by rustcollector on December 04, 2011 at 14:21:14 from (67.142.161.18):
In Reply to: M still not running posted by oldiron29 on December 04, 2011 at 14:02:57:
Oldiron,
Advance the timing to where the mag trips just before TDC, (should be about 4 degrees before TDC). Start with the carb screws at 1&1/4 turns out. Try a strong shot of starting fluid. If the engine hits but soon stops, fuel and the carb is the problem. Float level may not be set correctly or binding.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
