M still not running
Posted by oldiron29 on December 04, 2011 at 14:02:57 from (74.88.11.200):
To all that tried to give me advice last night the M is still not running. I begain today with removing valve cover and making sure I had TDC right by watching rocker and valves. TDC is correct. Pulled all plugs cranked with hand crank and I get spark on all just after compression so that is correct. Pull M with my Regular around the barn yard about a dozen times.
Did get some smoke after chocking. trottle closed and open but no good pops. So I am thinking it is starving for fuel. I removed carb and went through clean again all looks good opened main jet about 4 turns past original setting of 2 1/2 out. Did get 1 good pop with my hand over carb but than seems to flood. I am looking for something to blame Poor spark? could it be I got bad plug new out of the box? Champian D-21. Is 125-135 bad compression not pulling the gas up? Oh and When I had the carb off I run a wire up in the new manifold but no blockage found. What would you guys try next? This one is wheren me out. oldiron29
