Re: 1946 -A Farmall
Posted by T_Bone on August 31, 2000 at 22:00:25 from (207.254.53.120):
In Reply to: 1946 -A Farmall posted by Jeff B on August 31, 2000 at 20:52:22:
Hello Jeff, All I can say is with luck like mine and yours, if we both looked at a tractor at the same time it would never run again!
First I would run No 1 to TDC on compression, then check for flywheel timing mark alignment and check to see if distributor is ready to fire on No1 lobe on the cap. That will confim any out of timing problems if there not all in alignment. Check for spark next. Weak spark or no spark look for a loose wire from the ampmeter to the coil or switch. Sounds like you got spark with a backfire tho but a loose wire would let it not start. Try that and see what happens.
T_bone
Post A Followup
: Re: Re: 1946 -A Farmall
