Re: M still not running
Posted by El Toro on December 04, 2011 at 17:20:51 from (108.3.225.57):
In Reply to: M still not running posted by oldiron29 on December 04, 2011 at 14:02:57:
Hold your hand over the throat of the carburetor
while a helper attempts to start the engine. If there's very little suction you have low intake manifold vacuum. Could be a leak around the manifold. You need good suction to draw that fuel into the engine. When you're at TDC on the compression stroke your rotor should be pointing to your No1 plug wire which is about 2 o'clock. Your plug wires should be in this firing order on the cap. Hal
2-1
4-3 The rotor turns CW.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
