Re: M still not running
Posted by NEIADan on December 04, 2011 at 17:40:42 from (70.41.61.15):
In Reply to: M still not running posted by oldiron29 on December 04, 2011 at 14:02:57:
Ok if I am reading your post correctly. Your M is equipped with a mag. I assume it is an H-4 mag. Have you checked that your plug wires are correcly installed. Do not assume that the No. 1 cylinder and wire are correct. If theses mags have ever been removed the timing of the gears may have altered which distributor cap post is no. 1. Also check for carbon tracking on the distributor cap. Your cap or bad wires could allow cross firing where the spark would travel to the plug with the least amount of compression. Your testing would show every thing is good yet when you connect the wires they are crossing due to the higher resistance.
good luck
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
