Re: M still not running
Posted by Alont on December 04, 2011 at 17:46:54 from (174.35.231.87):
In Reply to: M still not running posted by oldiron29 on December 04, 2011 at 14:02:57:
rustred
Advance the timing to where the mag trips just before TDC, (should be about 4 degrees before TDC).
old iron29
I have checked timing #1 spark JUST AFTER after compression TDC.
rustred's suggestion will at least move the mag into the band
35 deg btdc-full retard
and
t.d.c.-full advance
Good Luck
Alont
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
